Activity Forums Panasonic Cameras User Clip Name HPX170
  • User Clip Name HPX170
    Posted by Richard Jernigan on July 29, 2009 at 3:24 am
    Any thoughts on controlling file names on P2 cards?
    I just tried adding a user clip name to my video files. I have a properly formatted SD card and have created a file name at metadata>property>user clip name (my user clip name was “july”). I shot a few clips and pulled them into FCP 5.01. The counter is working – but file names are still randomly named: 0001MF, 0002DP, 0003LB, etc.
    Will greatly appreciate anyone’s help!
    Richard
    Jeremy Garchow replied 17 years, 1 month ago 4 Members · 8 Replies
  • 8 Replies
  • Jeremy Garchow
    July 29, 2009 at 1:59 pm
    The UserClipName is stored in the metadata and does not name the files themselves.
    Jeremy
  • Arthur Aldrich
    July 30, 2009 at 1:04 am
    You need to make sure that the camera is using “type 2” metadata first. Then, to use this metadata in FCP, you will need to upgrade to FCP7 or use a program like Raylight or MXF4mac.
    All previous versions of FCP do not read P2 metadata. FCP7 is the first version to read the user clip name field.
    Art Aldrich
    OTEK TV
    Leader, NJFCPUG
    http://www.njfcpug.org
    http://www.otek.tv
  • Richard Jernigan
    July 30, 2009 at 1:35 am
    So is there any way to prename clips prior to shooting?
  • Bjoern Adamski
    July 30, 2009 at 8:53 am
    Clips names can’t be set, it’s the User Clip Name that can show up in FCP instead of the real file name.
    Don’t change the clip names, this will corrupt your P2 file structure.
    Product Manager
    MXF4mac
    https://mxf4mac.com
  • Jeremy Garchow
    July 30, 2009 at 3:42 pm
    [Richard Jernigan] “So is there any way to prename clips prior to shooting?”
    Yes, you can preload metadata to the camera so that every shot has all sorts of great information.
    Check this out first, and then write back with questions:
    ftp://ftp.panasonic.com/pub/Panasonic/Drivers/PBTS/papers/P2HDMetadata.pdf
    Jeremy
  • Richard Jernigan
    August 1, 2009 at 2:16 am
    Having read the PDF, it appears I need a P2 Viewer to add a User Clip Name.
    I’m a Mac user, and I don’t see Mac P2 Viewer at the Panasonic site (https://eww.pavc.panasonic.co.jp/pro-av/support/desk/e/download.htm).
    However, I heard that the HPX-170 allows a user to create a UCN inside the camera.
    Any thoughts on either of these?
    Richard
  • Richard Jernigan
    August 1, 2009 at 2:46 am
    I’ve just figured it out.
    I had set up a UCN in Metadata>Property but had not turned Record on at Metadata>Record. When you have a SD formatted disk in the camera, have Type2 switched ON and Record switched ON, the camera allows you to lay down a UCN as the file name followed by a four digit number.
    Thank-you everyone for your input.
    Richard
  • Jeremy Garchow
    August 2, 2009 at 5:30 pm
    You can use P2CMS on the Mac (free from Panasonic)
    or check out a new metadata editor called P2 Flow:
    https://mxf4mac.com/p2-flow
    It’s coming very soon.
    P2CMS will also save metadata files that you can save to your camera as well.
    Jeremy
