Activity Forums Adobe After Effects Useless error message – too much memory?
  • Useless error message – too much memory?
    Posted by Brodd Nesset on November 15, 2005 at 8:09 pm
    Upon adding some elements to my DV-movie of 36 mins length, I get this error message:
    Not enough memory available to create Audio data.
    522694 K required, 920422 K available
    As you can see, the latter number is nearly doble what is required. What goes???
    System info: AE6 on WinXP sp2 w/AMD64 3500, 1 gB RAM, 300+ gB disks, 512 mB RAM on OpenGL-card. No other programs are running when I attemt to do simple things like zooming the Timeline, making previews etc. and this message appears.
    Tomogomo replied 20 years, 9 months ago 2 Members · 1 Reply
  • Tomogomo
    November 15, 2005 at 11:54 pm
    Hi
    Just to be sure…You did change AE memory limit within preferences, right?
    If not the do it . This latter number indicates total physical memory on your system, but AE might not be allowed to use it all
    check it
    if this doesnt help then dunno
