Activity › Forums › VEGAS Pro › used to avid liquid, preview window?
  • used to avid liquid, preview window?
    Posted by Kevin Brown on April 21, 2010 at 3:42 pm
    I am used to avid liquid where I have two windows, one left one right. I can preview on the left window and take clips and drag them to the timeleine. In vegas platinum it only has one window. I see the “open in trimming window” but have no clue.
    any tips?
    Mike Kujbida replied 16 years, 5 months ago 2 Members · 3 Replies
  • Mike Kujbida
    April 21, 2010 at 7:05 pm
    Vegas works completely different than any Avid product so do yourself a favour and forget everything that you used to do.
    The Trimmer is what comes up when you select the “open in trimming window” option.
    You can play your footage and drop markers (shortcut is the M key) on it if you want to.
    If you want to select a specific piece of footage, drag the cursor to highlight the portion or double-click between a set of markers, right-click it and drag it to the timeline.
    Once there, you’ll have several options and it’s a matter of choosing the appropriate one.
    A lot of us, me included, rarely use the Trimmer and do all our cutting right on the timeline.
    BTW #1, the online help files in Vegas are very good and I encourage you to spend some time going through the various tutorials.
    BTW #2, the S key (for Split) is the equivalent to the razor blade.
  • Kevin Brown
    April 21, 2010 at 7:24 pm
    thanks. I got the S key down.
    I had to go to vegas from avid liquid because there was no mxf plugin for avid liquid, plus they are no longer supporting the project.
    The thing about editing on the timeline, which i do make adjustments, is the fact that if I want to add a short take in between two other cuts, I usually spend alot of time moving stuff to the right,a nd also plugging back and forth as my clip drops to the far right of the timeline.
    however it seems stable and works well for the price.
  • Mike Kujbida
    April 21, 2010 at 10:07 pm
    “…if I want to add a short take in between two other cuts, I usually spend a lot of time moving stuff to the right…”
    Look into the Auto Ripple tool as it’ll make doing this MUCH easier.
    Be advised that the usual recommendation is to enable it, do what you have to do and then disable it again.
    This is because it’s easy to forget that it’s enabled and then run into problems later because you forgot it was on.
