Activity › Forums › Broadcasting › Used Sony PVM-1354Q problem
  • Glenn Chan
    November 25, 2006 at 2:58 am
    The I and Q bars are not important, since (virtually) nobody uses YIQ encoding anymore.
    Calibration info (this calibrates the interface; it does not calibrate other aspects of the monitor):
    https://videouniversity.com/tvbars2.htm
    Try:
    Take a color image and de-saturate it completely in Ppro. Does this image appear perfectly black and white on the monitor? (Without color casts.) You can try using the color corrector to introduce color casts to train yourself so you know what to look for.
    Also try:
    With the B&W image, try calibrating the gain and bias settings under “user color” and “Color temp/bal”.
    2- Used monitors can be sketchy if they have image flaws. Some flaws are not worth fixing (just get a new monitor), and some flaws can’t be fixed (overused phosphors cause color casts). Returning the monitor may be the best bet?
  • Dorel Iordache
    November 25, 2006 at 8:39 pm
    Thanks for the input Glenn!
    [glenn chan] “Calibration info (this calibrates the interface; it does not calibrate other aspects of the monitor):
    ” target=”_blank”>https://videouniversity.com/tvbars2.htm
    That
  • Sbrand
    May 2, 2007 at 2:19 pm
    Never, ever buy a used monitor. Colors go out of wack with age.
    I would have recommended that you buy a new version of the Sony.
    Years ago, we compared it with other monitors and there was a radical difference.
    The sony monitors are the industry standard in broadcast. Mine is 12 years old.
    The investment was worth it.
