Activity Forums Audio Used Lectrosonics purchase strategy
  • Used Lectrosonics purchase strategy
    Posted by Lloyd Lemmermann on November 20, 2017 at 8:21 am
    I’ve decided to “buy once, cry once” and invest in a used tx/rx Lectrosonics set rather than go the G3 route. I’m bewildered by the options available, but will do further research to learn about the particulars of the various models. I come here to ask the following for the sake of my budget: What’s the wisdom, if any, in pairing a higher-end TX with a somewhat lower end RX or vice versa? From what I know so far it seems that 201 series and higher/newer is where I want to focus, but beyond that just not sure especially if I consider a “mixed” set.
    Thanks for your thoughts on this.
    Eric Toline replied 8 years, 9 months ago 2 Members · 1 Reply
  • Eric Toline
    November 21, 2017 at 2:10 am
    No advantage to mixing TX & RX from different series and the strong possibility that they won’t play nice together. Buy a matched set from the same series and be worry free.
    \”I push the RECORD button and hope for the best\”
