Activity › Forums › Storage & Archiving › Use volume mode on raid set up or not??
  • Use volume mode on raid set up or not??
    Posted by Matt Stoltz on January 4, 2011 at 6:11 pm
    Hey All
    I use a 2 drive housing Sans Digital enclosure. I have 2 1TB drives in there using it in a raid 0 setup
    Now the settings on the housing itself give me the option to use the enclosure as a 2 TB “Volume” drive or just using it as a 2TB drive.
    What is the “Volume” referring to? Is it better to use your drives in a raid volume mode
    Please help
    thanks
    Matt
    Fred Jodry replied 15 years, 8 months ago 2 Members · 4 Replies
  • Fred Jodry
    January 10, 2011 at 3:32 pm
    Make a really small (~40 GB or smaller) partition on each and test for yourself. Then you can zero out past the partitions and use your own best result.
  • Matt Stoltz
    January 18, 2011 at 3:49 pm
    Fred
    thanks for your response but Im really not sure what you mean –can you explain a little more -especially zero out past the partitions –
    you kinda lost me there
    matt
  • Fred Jodry
    January 19, 2011 at 6:44 am
    Instead of having to swap to a spare set of work hard drives every time you want to test “volumes setups”, a new tweak in your software, or whatever, have 2 per cent of each drive, after the main partition, set up as a test partition to test something. When you are done, wipe out the test such as deleting folders, or reach for a software utility to delete and zero out the test partition (on each work drive) and then make new ones (test partitions).
  • Fred Jodry
    January 19, 2011 at 7:00 am
    Whoa, Matt. It looks like you should ask the manufacturer or seller of the drives what this volumes stuff is. Sometimes the manufacturers give us too few instructions. Other times I think they`re writing exciting and different chapters about as fast as Rudyard Kipling would.
