Activity Forums Adobe After Effects Use two Photoshop Live 3D objects in a single After Effects comp?
  • Use two Photoshop Live 3D objects in a single After Effects comp?
    Posted by Mike James on January 8, 2012 at 11:11 pm
    I’d like to know if it’s possible to create a new comp in After Effects (CS5.5) and then import two Photoshop Live 3D models into the comp and then animate a camera around them? I can do this easily with a single imported PS 3D (PSD) model, but can’t figure out how to import a second 3D model to use in the same scene.
    For example, lets say I had two separate PS Live 3D models, one of a car, and the other of a motorcycle. How can I import both of these two models (saved as Photoshop .PSD Live files) into my comp and then use a single camera to orbit around both models in 3D space. I have a sneaking suspicion that this might not be possible and that I might have to learn how to use a dedicated 3D software package!
    Thanks for reading,
    Mike.
    Tudor “ted” jelescu replied 14 years, 7 months ago 3 Members · 2 Replies
  • Niccolò Ungaro
    January 9, 2012 at 12:48 pm
    I would suggest to render in alfa the first object (3D psd live) reimport the same in the comp. and than go on with the second one…
    Regards.
    nic.
  • Tudor “ted” jelescu
    January 9, 2012 at 7:12 pm
    Working with one PSD 3d layer is slow at it’s best. Two… I would not try. The first suggestion you got (render one w alpha and comp with the second) works if you do not want to tweak the animation/position. I would recommend Zaxwerks Invigorator Pro. You can bring in a few models, link them to AE 3d layers and position/animate them using the familiar AE controls.
    Tudor “Ted” Jelescu
    Senior VFX Artist
