Activity Forums Adobe After Effects Expressions Use text from a .txt file
  • Use text from a .txt file
    Posted by Jos Willem on August 7, 2013 at 12:32 pm
    I want to make 100 video’s with after effects. Each video is unique because the video is filled with personal data. To make the 100 video’s I want to use text from a .txt file. This works fine but… in the Expression I need a file path. But I don’t want to use a file path. (because I will automate the render batch)
    Is it possible to link to a .txt file (ae project and .txt file are located in the same folder) in a after effects project without define the file path?
    My Expression code I use now is:
    if ($.os.indexOf(“Mac”) != -1)
    filePath = “/Volumes/RAID1/jos/”;
    filePath += “textlist.txt”;
    $.evalFile(filePath);
    eval(thisComp.name);
    Jos Willem replied 13 years ago 2 Members · 2 Replies
  • Dan Ebberts
    August 7, 2013 at 1:38 pm
    I don’t know of any way for an expression to determine the path to the project file’s folder. It’s easily accomplished with a script though, so if you’re doing batch render automation, you might want to consider going that route.
    Dan
  • Jos Willem
    August 7, 2013 at 1:53 pm
    Hi Dan,
    I want to automate the process without changing the after effects project. The plan is to create a after effects project and a .txt file. Then make a automate script (Mac OSX) to copy the after effects project and the txt file to folders and change the content of the txt file. Then I use the watch folder of after effects to render the batch.
    But now I need to change the path to the txt file. Is it possible to link the txt file without using the complete path to the file?
    Jos
