Activity Forums Adobe After Effects Use stroke effect on paths from Illustrator file in After Effects?
  • Use stroke effect on paths from Illustrator file in After Effects?
    Posted by Stephen Pickering on April 22, 2013 at 4:37 pm
    Hi there,
    I’m wondering if it’s possible to save an illustrator file in such a way for it to be used in After Effects, retaining it’s paths. I would like to use the Stroke effect then to reveal (or draw) the paths.
    I know I can draw masks in AE and then apply the stroke effects to stroke all masks sequentially, but it’s much easier to draw/write in Illustrator than AE.
    Am I hoping for something impossible?
    -Stephen
    Stephen Pickering replied 13 years, 5 months ago 2 Members · 2 Replies
  • John Cuevas
    April 22, 2013 at 5:26 pm
    If you have AI and AE open at the same time, you can select your paths in illustrator, copy them and then paste them to a solid in AE.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Stephen Pickering
    April 22, 2013 at 7:42 pm
    This will work great. Thank you so much!
