Activity Forums Apple Final Cut Pro Legacy use sharing older to share media
  • use sharing older to share media
    Posted by Tel Jaba on June 12, 2009 at 12:17 pm
    I have three edit stations on the same network
    do you think it is a good idea to use the file sharing folder for one station to access the other and share media and other files?
    Arnie Schlissel replied 17 years, 3 months ago 2 Members · 1 Reply
  • Arnie Schlissel
    June 13, 2009 at 12:58 am
    There’s no reason for you not to use the network to share files. You can certainly copy files from one mac to another.
    If you want to edit on one mac with media on another over the network, though, you’ll probably need to use something faster than your existing network, and you may need to work with compressed codecs like DVCPro HD, XDCam or ProRes
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
