Activity › Forums › Adobe After Effects Expressions › Use script to retrieve value from expression
Posted by Oscar Nyquist on October 2, 2020 at 2:24 pmHello,
I’m trying to create a script that will resize my comp according to a value retrieved from an expression within the comp. First of all, is this even at all possible? If so, I would love some assistance on how this would be done, or pointers to any relevant resources.
Many thanks in advance!
Oscar Nyquist replied 5 years, 11 months ago 3 Members · 8 Replies -
Dan Ebberts
October 2, 2020 at 3:12 pmHere’s a simple example that gets the comp width from a slider control that has an expression:
var myComp = app.project.activeItem;
var myWidth = myComp.layer(1).property("Effects").property("Slider Control").property("Slider").valueAtTime(0,false);
myComp.width = myWidth;
Oscar Nyquist
October 2, 2020 at 9:25 pmWow, this was exactly what I was looking for, and I thought it would be much more complicated. Thank you so much!
While I have you, another possibly more difficult obstacle: would it be possible to create a solution for scaling font size with say comp width?
Brendon Murphy
October 3, 2020 at 4:24 amYou can do it dynamically with an expression on scale:
compWidth = thisComp.width;
compHeight = thisComp.height;
ratioX = value[0]/1920; //replace 1920 with your original comp width
ratioY = value[1]/1080; //replace 1920 with your original comp height
newSizeX = compWidth*ratioX;
newSizeY = compHeight*ratioY;
[newSizeX,newSizeY];
You’ll need to script out the position as well if you want the text to stick in place, or have your anchor point in the center of the comp.
Oscar Nyquist
October 15, 2020 at 12:37 pmApologies for the late reply.
This solution was much more elegant than the one I came up with at first, and seems to be working perfectly together with my positioning expressions. Thank you too!
Brendon Murphy
October 15, 2020 at 7:04 pmHey Dan, silly question here. How do you reply with your code in a separate box? I’ve noticed the forum font does some bad things when I paste replies directly in the reply box.
Dan Ebberts
October 15, 2020 at 7:33 pmOnce you start entering text, you can click on the Aa below to expose text formatting options. Move to a new line and click the </> for preformatted text and paste your expression in the box. What I haven’t figured out is how to keep it from double spacing the lines. Maybe someone will reveal that trick…
Oscar Nyquist
October 19, 2020 at 8:16 amI’ve tried adding a function to the script, but this is a bit above my level so I just wanted to ask for a little more help.
I would like the script to check for precomps with a specific name and then resize that comp to the same size as the main comp. So, let’s say, if the main comp contains a precomp named “one” and/or “two”, resize them. If they don’t exist, then do nothing.
I understand this might be a little complicated, so any pointers in the right direction are appreciated. Thanks!
