Activity › Forums › Adobe After Effects Expressions › Use script to freeze on last frame for 2 seconds
  • Use script to freeze on last frame for 2 seconds
    Posted by Rob Packer on November 16, 2021 at 2:41 am
    I am attempting to freeze a layer (vidL) on it’s last frame, and extend the layer and composition by 2 seconds.
    Using the code:
    vidL.timeRemapEnabled = true;
    vidL.property(“timeRemap”).setInterpolationTypeAtKey(1,KeyframeInterpolationType.HOLD);
    results in the layer freezing from the first frame.
    The following function throws an error code# 1: Unable to call “setValueAtTime” because of parameter 2. Value 19.96 out of range 0 to 18. However, when the code is halted, the freeze on last frame has worked, but not extending the layer.
    function freezeFrame(){
    vidL.startTime = 0;
    var vidLength = vidL.outPoint;
    compVideo.duration = vidLength + 2;
    var timeRemapProp = vidL.property(“ADBE Time Remapping”);
    var currTime = vidL.outPoint;
    var lastTime = currTime + 1.96;
    timeRemapProp.setValueAtTime(currTime, lastTime);
    Any help would be appreciated.
    Meng Zhiqun replied 4 years, 10 months ago 2 Members · 3 Replies
  • Meng Zhiqun
    November 16, 2021 at 4:29 am
    You can try this. if targeting layers is required, select them before executing the script. If not, use this without selecting any layers.
    var projComp = app.project.activeItem;
    var selLay = projComp.selectedLayers;
    var addTime = 2;
    function addCompTime(item){
    if(item.timeRemapEnabled == false){
    item.timeRemapEnabled = true;
    item.outPoint = item.outPoint+ addTime;
    }else{
    app.beginUndoGroup("setOutPoint");
    if(selLay.length > 0){//Select layers in comp
    for(var i = 0; i < selLay.length; i++){
    var curLay = selLay[i];
    try{
    addCompTime(curLay);
    }catch(e){
    curLay.outPoint += addTime;
    }else{
    projComp.duration += addTime;
    for(var i = 1; i <= projComp.numLayers; i++){
    var curNSLay = projComp.layer(i);
    if(curNSLay.source.typeName != "Composition"){
    curNSLay.outPoint += addTime;
    }else{
    addCompTime(curNSLay);
    app.endUndoGroup();
  • Rob Packer
    November 22, 2021 at 1:20 pm
    Thanks for the help Meng Zhiqun.
    Because I am the end user, and I have done error checking elsewhere in the script, I trimmed it down to this:
    var compVideo = app.project.item(3); // the video composition – which because of the naming structure will be the 3rd composition
    var vidL = compVideo.layer(4); // the actual video layer in the video composition – will be layer 4
    var addTime = 2;
    function freezeFrame(vidL){
    item.startTime = 0;
    compVideo.duration = item.outPoint+ addTime;
    Apologies for the late response.
  • Meng Zhiqun
    November 22, 2021 at 5:44 pm
    Hey Rob,
    Of course! My examples were done in a rush. So I’m glad u could proof read it. 🙂 Have fun!
