Activity Forums Maxon Cinema 4D Use plain effector on individual letters in C4D
  • Use plain effector on individual letters in C4D
    Posted by Joe Rigby on October 14, 2018 at 8:33 pm
    Hello, I recently aquired this C4D project file and I am absolutely baffled by how this person was able to animate the individual letters with a plain effector. I’ve been trying to decipher the project for hours. I believe that the text was probably made with motext and then made editable and placed under a fracture for some reason? The plain effectors are effecting the fracture and I don’t understand how they are only effecting the individual letters. I have uploaded the project file. You can see the letter ‘N’ and ‘Y’ being effected individually. Its probably something really easy and simple and i’m just being dumb. Thanks.
    12806_indivlettersproj.c4d.zip
    Joe Rigby replied 7 years, 10 months ago 3 Members · 3 Replies
  • Brian Jones
    October 15, 2018 at 2:22 am
    the Y and N have keyframe animation on them (look in their Coord tabs). The Fracture is so you can apply effectors to them since anything in a fracture is considered a clone, he (I assume by the Simon) could have used a MoText except that to animate the Y and the N separately he had to make it editable (or never started with MoText in the first place).
    If you turn off the fracture to disable the mograph stuff you can see what the base animation (camera and letters) is doing, try turning off the camera as well.
  • Emir Bojorquez
    October 15, 2018 at 2:23 am
    For what i can see, the fracture is for the plain and the delay, the plain is in box falloff and gives the illusion of individual letters having the effect. And the delay is in Spring mode, because the letters are separated objects, the delay acts close to one at the time.
    Hope that helps.
    Good Luck
    Imagination is the best tool…
  • Joe Rigby
    October 15, 2018 at 11:21 am
    Thank you very much for spotting this! Can’t believe I never noticed this in the first place, it’s such a simple thing! But now I know to do it, cheers buddy.
