Activity Forums Adobe After Effects use of 1view,2view in composition window?
  • use of 1view,2view in composition window?
    Posted by Ayas Hassan on March 9, 2006 at 8:51 am
    Hi
    whts th use of th tab 1 view,2views horizontal vertical etc on th bottom right side of th comp window?
    i use AE 7… and i tried clicking it, but it just shows th same composition in two views… can we c different compositions at the same time using this button? if yes how do we do that?
    thanx
    Ayas
    Nirvana Digital Post FZ LLC
    Dubai Media City
    Josh Miller replied 20 years, 6 months ago 2 Members · 1 Reply
  • Josh Miller
    March 9, 2006 at 8:59 am
    I use them to view different views (Active, Top etc.) in a 3D setup but I think you can view different comps in each one. You need to click inside the view you want to change and you’ll see a orangy line around the edges of the frame, then you can change the view or resolution etc.
    Josh
