Activity Forums Adobe After Effects Use multiple soundkey outputs to one value
  • Use multiple soundkey outputs to one value
    Posted by Sam Kennedy on December 11, 2019 at 5:55 pm
    Hello,
    I am trying to use trapcode form to create a type of audio react effect by using the outputs to change the value of x displace. Is it possible to use multiple soundkey outputs on one value; is there an expression for that?
    Walter Soyka replied 6 years, 9 months ago 2 Members · 1 Reply
  • Walter Soyka
    December 12, 2019 at 2:21 pm
    [Sam Kennedy] “Is it possible to use multiple soundkey outputs on one value; is there an expression for that?”
    Sure, you can have one output react to two inputs — it’s just math — but you do need to explain a little bit about how you want them to work together.
    If you want a cumulative effect, you can just add the values together (like ‘value1 + value2;’). If you want to react to whichever one is loudest, you can use a maximum function to return the bigger value like (‘Math.max(value1, value2);’). If you want some other interaction, let’s discuss what you’d want to see happen.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
