Activity Forums Maxon Cinema 4D Use Multi Instance without cloner for manually placing copies
  • Use Multi Instance without cloner for manually placing copies
    Posted by Nayan Chhaniyara on July 11, 2020 at 5:31 am
    So I am working on a architectural project and I have huge detailed assets of carvings, I want to clone these assets to a specific position in my scene using multi-instance as it won’t eat up my memory compared to render instance, I was wondering is there a way to do so?
    i.e. if I make instance object of the asset and use it in multi-instance mode nothing shows up in viewport as well as in render, but when i use it in render instance mode it shows up fine.
    Thanks for this great community of creative cow
    Nayan Chhaniyara replied 6 years, 2 months ago 2 Members · 2 Replies
  • Brian Jones
    July 11, 2020 at 8:07 pm
    I think the MultiInstance can only be used with a Position Source for where the instances will go. And the only difference, as I read it, is that multi-instance makes all the instances a single object a single object (internally) so viewport performance will be quicker compared with Render Instances.
  • Nayan Chhaniyara
    July 12, 2020 at 6:07 pm
    Thanks this was really helpful
    Nayan,
    CG Artist, Akshar Chalchitram Studios
