Activity › Forums › Apple Final Cut Pro › use markers to make edit notes
  • use markers to make edit notes
    Posted by Jason Brown on April 24, 2018 at 12:47 am
    Maybe I’m going about this the wrong way, but I like using markers to create time notes for feedback to my editor working on a Premier system. I usually just take a screengrab of where my comments line up with a timecode of where the marker is in the timeline. It works great unless I write more than 6 words…you can’t make that column wide enough to display everything I’ve written. It’s surprisingly limiting. Is there a way to get that data out another way?
    Andreas Kiel replied 8 years, 5 months ago 3 Members · 2 Replies
  • Bill Davis
    April 25, 2018 at 7:37 pm
    It requires an investment, but the industry is generally moving to on-line stored notes systems for stuff like this. The class of the pack is Frame.io
    It gives you the ability to attach notes directly to frames in a shared cloud experience and works within both FCP X and Premiere.
    If you don’t want something that sophisticated, you can also just do the traditional thing and pop a timecode generator atop your timeline as a kinda/sorta adjustment layer – then take notes in a word processor linked to those.
    It’s the only way I know of to exchange notes linked to video between two editors working on totally different software platforms.
    Creator of XinTwo – https://www.xintwo.com
    The shortest path to FCP X mastery.
  • Andreas Kiel
    April 25, 2018 at 8:11 pm
    Jason,
    I’m not sure what exactly you mean or want to do.
    What are the screenshots for?
    Spherico
    https://www.spherico.com/filmtools
    \”He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil
