Activity Forums Adobe After Effects use luma map to displace position
  • use luma map to displace position
    Posted by Johnny Mabie on February 8, 2018 at 1:44 am
    I would like to use a luma gradient map to effect the position value on individual layers. For example:
    Start with:
    a) a row of shape layers laid out horizontally across the comp
    b) a white-to-black horizontal gradient map off the left side of the comp
    As the gradient map moves from left to right across the comp, each shape layer’s y-position increases as the luma value behind it increases from black to white.
    There must be an expression or string of expressions that can achieve this. Any ideas?
    Cassius Marques replied 8 years, 7 months ago 2 Members · 1 Reply
