Activity Forums Adobe After Effects Use light as motion target
  • Use light as motion target
    Posted by Bart on February 8, 2007 at 12:30 pm
    I have a footage that I use to track a motion. Now i want a light in AE to follow this path. Thing is that I can’t select the light as the motion target. Is this even possible or should I convert one of the layers to some sort of other layer ?
    Many thanks in advance,
    Bart
    Bart replied 19 years, 7 months ago 2 Members · 3 Replies
  • Tyler Paul
    February 8, 2007 at 1:40 pm
    You could apply the motion tracking to a null object then set an expression to the lights position layer. Just pickwhip the position to nulls position.
  • Bart
    February 9, 2007 at 11:03 am
    Thanks Paul, It worked. But unfortunately it didn’t work for the thing i’m trying to achieve. I want to create a writing effect with the trapcode Particular plugin. In the tutorial the path of the emitter is arranged with the expression (wiggle(.5,100). I Changed this path the path of the tracker. So i imported the image-sequence and used a null-object for the motion target and pickwhip the position of the emitter to nulls position.
    I would expect this to work but it doesn’t. Hope you see what I’m trying to accomplish here and could give me some tips.
  • Bart
    February 11, 2007 at 9:45 am
    anyone ?
