Activity Forums Adobe After Effects Use Generated Waveform as Path
  • Use Generated Waveform as Path
    Posted by Andy Benham on October 11, 2018 at 12:18 pm
    Hello all,
    I’m using the AE waveform generator (playing in a ‘white noise’ file) for some technical videos I’m making to demonstrate a waveform.
    Can I use this generated waveform as path for a cursor to follow, I want a ‘dot’ to ride along on this generated wave much like a traditional cathode-ray ‘scope, whilst still displaying the wave.
    Any pointers how I can do this, I’ve placed the wave-form on to a solid?
    Kind Regards,
    Andy.
    Michael Szalapski replied 7 years, 11 months ago 3 Members · 2 Replies
  • Kalleheikki Kannisto
    October 11, 2018 at 2:00 pm
    For a simple solution you could try making a copy of the waveform and then animate a vectical slit to move across the screen and use it as a track matte for the copy, essentially slicing a little section of the waveform to generate the “point”. It may look just fine for your purposes.
    Senior Graphic Designer
  • Michael Szalapski
    October 12, 2018 at 3:40 pm
    I like this idea! A couple of linear wipes (offset from one another with an expression for ease of use) would get you a tiny slice. You could then apply blurs and/or glow effects to make a little dot traveling along the line.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
