Use external text from csv file
Hello there. I have a problem setting up my new project. I created a simple file in Excel which contains some data. One cell in Excel has a drop-down list, to choose some text from multiple options. When I enter all the data I export to CSV. Here is the thing, I have a several different layers, which are quick time animations, with the exact name as the text in drop-down list in Excel. All those quick time animation layers are in the same comp. I want to create an expression which turns on layer with the name matching with the corresponding text chosen in the Excel file. I tried via some opacity expressions but no luck. In essence, if I chose text “shoes” in Excel drop-down list, I want layer with name “shoes” to be only visible in After effects. I don’t know if I described this right. Any help would be appreciated.
Thanx in advance.
Radoman.
