Activity Forums Sony Cameras use existing zoom control on EX3
  • Klaas Van urk
    November 16, 2008 at 2:41 pm
    The 9 pin male is moulded to its wire, so I couldn’t open it. I think you buy it with the wire already attached. I could open the 8 pin female connector, the pins are marked with letters. These are my findings:
    The white wire is connected to pin A, gray to pin B, red to C, blue to D, black to E and G (bridged), yellow to F, orange to H. The brown wire is ignored.
    So if you find a 9 pin male connector wired according this colorscheme, you’re set.
