Activity Forums Adobe After Effects Use Effects to Duplicate Layer Within Itself?
  • Use Effects to Duplicate Layer Within Itself?
    Posted by Demian Krentz on February 25, 2014 at 7:04 pm
    I have three layers:
    Title A
    Copy of Title A
    Background
    Both text layers identical layer styles applied and have their transfer mode set to Multiply. To get the look I want, I need to duplicate the text layer so that it “doubles up the density” so to speak so that the multiply factor is more intense.
    Is there a way to achieve the same effect without Copy of Text A? Is there a way to duplicate a layer within itself? Some sort of Channel Combiner or Arithmetic operation? I’d like to avoid needing to deal with two text layers for each title. I know I can link attributes, parent, etc., but that’s even more work for each title.
    Any help or advice is appreciated.
    Todd Kopriva replied 12 years, 6 months ago 3 Members · 9 Replies
  • 9 Replies
  • Todd Kopriva
    February 25, 2014 at 8:12 pm
    Check out the CC Composite effect. Using the Add blending mode within that effect should do what you want, if I’m understanding you correctly.
    After Effects team blog
  • George Goodman
    February 25, 2014 at 8:17 pm
    You don’t have to deal with two separate layers if you parent the layers and then parent the source text. Then if you update the parent text, the child text will update as well.
    “|_ (°_0) _|”
    Sincerely,
    George
  • Demian Krentz
    February 25, 2014 at 8:25 pm
    No, I understand that. I’m trying to avoid needing a second text layer entirely.
    Edit: And thanks anyway. 🙂
  • Demian Krentz
    February 25, 2014 at 8:27 pm
    Yes, I tried that at first. No dice. I apply it, switch the mode within to Add (or any other mode), and nothing changes. It’s like I’m not applying that effect at all.
    But it doesn’t seem like the correct effect anyway, yes? I’m not trying to combine the effect with the layer, I’m trying to duplicate the layer within itself. Almost like precomposing two copies of the same layer within one layer, but without actually precomposing (and not needing a second layer to act as a reference).
    I know I’m missing something here…
  • Todd Kopriva
    February 25, 2014 at 11:34 pm
    The CC Composite effect has exactly that result: combining the layer with itself. Show me a screenshot of your Timeline panel and Effect Controls panel where you’re trying this. I just gave it a shot, and it worked fine for me; using Add within the CC Composite effect gave the result that I thought that you were asking for.
  • Demian Krentz
    February 25, 2014 at 11:39 pm
    I have a feeling that it doesn’t work with layer styles?
  • Todd Kopriva
    February 26, 2014 at 12:07 am
    Ah. That is a crucial detail.
    Layer styles are applied last in the render order, since they are an extension of blending modes. So, no, this effect will not accomplish what you want if you are also using layer styles.
  • Demian Krentz
    February 26, 2014 at 12:16 am
    I suppose I should have worded it better (and used proper grammar) in my original post. Thanks anyway for trying. Any other ideas?
  • Todd Kopriva
    February 26, 2014 at 12:35 am
    Precompose, and then use the CC Composite effect on the precomposition layer.
