Activity Forums Apple Final Cut Pro Legacy Use Compressor to export to AVID DNXHD CODEC
  • Use Compressor to export to AVID DNXHD CODEC
    Posted by Ariel Brener on September 12, 2010 at 8:56 am
    Hey all,
    I have installed AVID CODEC PACK LE
    Currently I use FCP to export to DNXHD and its working OK (but VERY slow).
    I wanted to know if it is possible for me to use COMPRESSOR to export to AVID DNXHD CODEC.
    I need it because a lot of times I need to export to this codec (for AVID System that does the Promos)
    And I don’t want to use FCP for that because I want to keep working While I’m editing.
    If Compressor can’t export to DNXHD can I use QUICKTIME TO EXPORT TO DNX HD?
    ________٩(̾●̮̮̃̾•̃̾)۶________
    New Rig (Leopard 10.5.7):
    Final Cut Studio 3
    CPU: Core i7 920
    RAM: 12gig
    GPU: GTX 285 2GB OC
    HDD: 6 X 1 TB HDDs: 4 HDDs in RAID-5 and 2 HDDs for System.
    OLD RIG (Win Vista Ultimate 64bit):
    ADOBE MASTER COLLECTION CS4
    RAM: 8GB (Corsair 800Mhz)
    CPU: Intel Quad Core 2.4Ghz (Q6600)
    GPU: ATI x1950XT 256MB
    MB: Asus P5K Deluxe WiFi-AP
    John Pale replied 15 years, 11 months ago 4 Members · 9 Replies
  • 9 Replies
  • Rafael Amador
    September 12, 2010 at 9:46 am
    Hi Ariel,
    If you can export from FC, you should be able to export from Compressor and any other application able to export QT.
    rafael
    http://www.nagavideo.com
  • Ariel Brener
    September 12, 2010 at 11:40 am
    Thanks man – I rushed to the forum before trying to feedle with it myself…
    I found all the options I needed and eved created a nice little droplet 😀
    as always – thank you rafael!
    Final Cut Studio 3
    CPU: Core i7 920
    RAM: 12gig
    GPU: GTX 285 2GB OC
  • Julian Roberts
    September 12, 2010 at 6:51 pm
    Did you manage to get it to run any faster?
    Julian
  • Ariel Brener
    September 12, 2010 at 7:17 pm
    I didn’t try to time bench it.
    but I feel that FCP studio engine does not use the potential of the system resources.
    While exporting or rendering I look at the activity monitor and see that it uses only a fraction (about 1/8) of the 8 cores of my INTEL Mac pro ..
    I use adobe premiere CS4 and MEDIA ENCODER – and I see that ADOBE maximizes the rendering alot better.
    I don’t understand why FCP studio does not…
  • John Pale
    September 12, 2010 at 7:26 pm
    You can configure Compressor, using the QMaster control panel, to utilize all cores of your computer.
    This can dramatically increase the speed of your encoding.
  • Ariel Brener
    September 12, 2010 at 8:04 pm
    Sounds very interesting!
    I will look for info about it
    can you recommend on a nice link\tutorial on the subject?
  • John Pale
    September 13, 2010 at 12:28 am
    Open Compressor Help and then select “Distributed Processing Setup Guide”, then read the section called “Getting Started Quickly”
    This will take you through setting up a QuickCluster, which will, in many cases, greatly speed up your encoding by running multiple instances of Compressor using each of your processor cores.
  • Ariel Brener
    September 13, 2010 at 12:39 am
    Thanks a lot John,
    I will read it 2morrow.
    BTW I have 3 MAC PROS in the studio – I believe I can use this method for distributing across other machines as well..?
    thanks again
    Ariel
  • John Pale
    September 13, 2010 at 1:31 am
    [Ariel Brener] “BTW I have 3 MAC PROS in the studio – I believe I can use this method for distributing across other machines as well..?
    thanks again”
    Yes. You can. Fasten your seatbelts.
