Activity › Forums › Video Copilot › Use Composition as Texture
  • Use Composition as Texture
    Posted by Sam Roe on February 10, 2013 at 4:09 pm
    Is this possible? I have a project I’m working on and would like to just apply a composition as a texture on a flat plane that I can use E3D to light the plane and animate it… I don’t want to render out the texture before applying it though, because it’s animated and I’d like to easily be able to make changes to it. Is this a possibility with the plugin?
    Joseph W. bourke replied 13 years, 7 months ago 2 Members · 1 Reply
  • Joseph W. bourke
    February 12, 2013 at 2:40 am
    I have used it several times – you just need to make sure that your animated layer is in the Custom list for Textures. Then it can be applied to a model. The only thing disappointing is that alpha channels in the layer will not show up. I think this is a limitation of OpenGL.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
