Activity Forums Adobe After Effects Expressions Use Comp Name to drive position expression
  • Use Comp Name to drive position expression
    Posted by Criis Daw on October 25, 2012 at 12:28 pm
    Hi Everyone..
    I have tried following some previous threads but cant get it to work so i give up.. I’ll ask
    I am trying to get the comp name , specifically the last number to determine to position of a layer in the comp.
    ie
    Screen01_frame01_flap_01
    etc I would like to be able to link the y postion to the number of the flap.
    Anyone ??
    Criis Daw replied 13 years, 10 months ago 2 Members · 6 Replies
  • Dan Ebberts
    October 25, 2012 at 3:25 pm
    Something like this should work:
    nameSplit = thisComp.name.split(“_”);
    compNum = parseInt(nameSplit[nameSplit.length-1],10);
    value – [0,compNum*100]
    Dan
  • Criis Daw
    October 26, 2012 at 9:58 am
    thanks for that..
    will try it now..
    back in a minute when i mess it up ..
    cheers
  • Criis Daw
    October 29, 2012 at 4:06 pm
    Hi
    dont supose you could help me a little more could you .
    I copy the expression into the postion property and I understand how the y postion is calculated.
    for example comp number 17 in a comp 52 pixels high ends up with a Y value of -2530.
    why is that ..?
    If I understood how this number is attained I could make it so I get the number I want which is, (comp number-1)*52 . the height od the comp
    thanks
  • Criis Daw
    October 29, 2012 at 4:19 pm
    ahhh
    its ok .
    I figured out why it was not what I expected. the expression is applied to the value of the layer .. which I had already set…I works fine if I reset it to zero.
    Still If you have 5 minutes to explain a little i would be very thankful.
    cheers
    Chris
  • Dan Ebberts
    October 29, 2012 at 10:48 pm
    The part that converts the comp name to a number? It’s all core JavaScript. The split() function to split the comp name into an array of strings, using “_” as the delimiter. The comp number will be in the last element of the array, which you access with nameSplit[nameSplit.length-1]. Then you use parseInt() to convert the string version of the number to a decimal number.
    Dan
  • Criis Daw
    October 30, 2012 at 5:26 pm
    thanks..
    i understand i a little better.
    thanks for your help with this
