Activity › Forums › Adobe After Effects Expressions › Use Comp Name as layer index value?
  • Use Comp Name as layer index value?
    Posted by Anders Hattne on June 8, 2012 at 12:07 pm
    I’m planning on duplicating a bunch of comps. First comp is called “1”. When duplicating next one will be 2 and so on.
    I was hoping to use these comp names as values in order to retrive data from layers in another comp. So the comp “2” would refer to layer 2 in this other comp.
    I tried this:
    cubeNumber=thisComp.name;
    src=comp(“valores-colores”).layer(cubeNumber);
    Which doesn’t work since cubeNumber is a name and not a value.
    Is there a way of turning the comp.name into a value?
    There’s a hundred layers so I was hoping to avoid changing all duplicated comps ….
    http://www.ardillamedia.com
    Anders Hattne replied 14 years, 3 months ago 2 Members · 5 Replies
  • Dan Ebberts
    June 8, 2012 at 3:42 pm
    Try this:
    cubeNumber = parseInt(thisComp.name.split(” “)[1],10);
    Dan
  • Anders Hattne
    June 8, 2012 at 3:43 pm
    Seems like I may have gotten it:
    myInteger = parseInt(myString);
    Didn’t know about the parsing term and find it generally a bit tricky to find information on these things.
    is this Javascript? And do most javascrips ..functions work in AFX?
  • Anders Hattne
    June 8, 2012 at 3:45 pm
    Oh thanks! Seems as you replied justa as I found the information..
    In the end the comp names when duplicating have turned out to be “0 50, 0 51, 0 52, 0 53….” But I guess I can find my way around splitting it up and only using the last 2 digits.
  • Dan Ebberts
    June 8, 2012 at 3:48 pm
    >is this Javascript?
    Yes it is.
    Pretty much all the core stuff–everything except the stuff used specifically for web pages.
    Dan
  • Anders Hattne
    June 11, 2012 at 11:28 am
    Final expression that I used:
    First comp was named cubo 01.. then duplicated
    nombre=” “+thisComp.name;
    nombre1=nombre.substr(5);
    layerNo = parseInt(nombre1);
    src=comp(“valores-colores”).layer(layerNo );
    works like a charm!
