Activity Forums Adobe After Effects Expressions Use array to add Item to Comp with specific words (Script)
  • Use array to add Item to Comp with specific words (Script)
    Posted by Scott Mcgee on February 4, 2018 at 10:28 pm
    I have a script that duplicates my Comps *5 no problem. Then a separate script I’m trying to join up to this.
    This script below works fine on it’s own, but what I want to do is create an array. [“BL”,”CF”,”LS”,”LV”,”TS”,”TW”] so that it can go through my project and it adds my footage to the corresponding comp.
    Footage Item “BL-ANIMATE”
    Comp1 “BL-BUMPER-IN”
    Comp2 “BL-BUMPER-OUT”
    I’m fine if it’s the activeItem, it’ll still be a timesaver if I can use the Array to use the string of the first two letters to know which footageitem to use, but I can’t seem to get the Array to work. I nearly got it to work, but it would only add the first item in the array and it also added the last item in the project (Which was a comp) three time. Bizarre.
    var footageName =”BL-ANIMATE”;
    var myProject = app.project;
    var myComp = myProject.activeItem;
    var myFootage = null;
    for (var i = 1; i <= myProject.numItems; i++){
    myFootage = myProject.item(i);
    if (myFootage.name == footageName && myFootage instanceof FootageItem){
    break;
    if (myFootage == null){
    alert (“Can’t find ” + footageName);
    }else{
    myComp.layers.add(myFootage);
    Scott Mcgee replied 8 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
