Activity › Forums › Adobe After Effects › Use a text layer as alpha mask for line, but not touching, and rounded
  • Use a text layer as alpha mask for line, but not touching, and rounded
    Posted by Andrei Popa on October 18, 2024 at 3:18 pm
    Hi all.
    I have a problem in using a text layer as a mask for a shape layer that should be “Shy” to the text, as in it should not touch it. I succeeded doing this by duplicating the layer, adding a stroke to the duplicate, and using that as a mask for the line.
    The problem I am facing is that I would like the line to end rounded, because now it is very sharp whenever it intersects the text.
    THanks,
    Andrei.
    Brie Clayton replied 1 year, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • John Cuevas
    October 21, 2024 at 1:51 pm
    Does your line need to go in between the letters like in the example(blue lines) or can it stop at the start/end of each line(red lines)?
  • John Cuevas
    October 21, 2024 at 2:58 pm
    Maybe the answer will make a difference to others, my attempted solution isn’t working. Sorry
  • Andrei Popa
    October 22, 2024 at 6:22 pm
    I dont think I need it to be there between the lines. I can create a rectangle that will follow the text size. I just want to find out if there is a way to make it round when it intersects the alpha mask.
    Thank you for your insight
  • John Cuevas
    October 23, 2024 at 3:14 pm
    You might want to try in the expressions forum. I think you could your line that gets masked from the text alpha. Then create a round cap for it. There are search expressions that could find the end of your line post masking and then attach your round cap to it.
    I found years ago online and saved it, but I couldn’t modify it exactly for what you want, but perhaps, one of the experts in the other forum will be able to help you.
  • Vasyl Iskovych
    October 25, 2024 at 1:05 pm
    Hi there.
    Perhaps you could achieve something similar with effects?
  • Andrei Popa
    January 9, 2025 at 7:00 am
    Thank you Vasyl,
    That is exactly what I was looking for.
  • Brie Clayton
    January 9, 2025 at 2:40 pm
    Thank you, Vasyl, for solving this!
