Activity Forums Adobe After Effects Expressions Use a script to apply an expression to a selected property
  • Use a script to apply an expression to a selected property
    Posted by Kevin Snyder on October 3, 2021 at 8:22 pm
    How do you write a script to apply an expression to a selected property? I’ve looked around old post, but many of them are older and no longer work. I’ve tried modifying them without any luck. Thanks.
    Kevin Snyder replied 4 years, 10 months ago 2 Members · 4 Replies
  • Dan Ebberts
    October 3, 2021 at 8:28 pm
    This would be the basics:
    var myComp = app.project.activeItem;
    var myProps = myComp.selectedProperties;
    var myExpr = "value";
    for (var i = 0; i < myProps.length; i++){
    if (myProps[i].canSetExpression) myProps[i].expression = myExpr;
  • Kevin Snyder
    October 3, 2021 at 11:08 pm
    Thanks, Dan. I appreciate it. For some reason, it’s still throwing an error.
    When I use the script below I get a message stating “Unable to execute script at line 5. Expected: ;”
    var myExpr = "thisComp.layer("Master Null").effect("Drive")("Output 01")";
  • Dan Ebberts
    October 4, 2021 at 12:07 am
    In line 3, you’ve got conflicting quotes. Try it this way:
    var myExpr = 'thisComp.layer("Master Null").effect("Drive")("Output 01")';
  • Kevin Snyder
    October 4, 2021 at 4:21 am
    Great! Thank you.
