Activity Forums Apple Final Cut Pro Legacy Use 422 LT for Sony NEXVG10 Transfer?
  • Use 422 LT for Sony NEXVG10 Transfer?
    Posted by Mark Fanjoy on September 27, 2011 at 3:19 pm
    I want to ingest footage shot on my Sony NEXVG10 into FC. I want the closest lossless output I can achieve going to Blu-Ray.
    Is the ProRes 422(LT) codec plenty for me to use to ingest from this camera? Do I really gain anything (other than twice and three times the file size!) using 422 or 422(HQ)?
    I recall reading somewhere that depending on the BIT rate, it is a waste of space to ingest with a higher codec when the lower codec will capture a lossless picture just fine.
    Thanks in advance for a clarification.
    Wherever I am…I’m lost!
    Rafael Amador replied 14 years, 11 months ago 2 Members · 1 Reply
  • Rafael Amador
    September 27, 2011 at 5:20 pm
    Everything down from Uncompressed down degrades the picture.
    You may see it or not, but compression is there.
    [Mark Fanjoy] “I recall reading somewhere that depending on the BIT rate, it is a waste of space to ingest with a higher codec when the lower codec will capture a lossless picture just fine.”
    That statement goes against all the laws of the physics .
    If a low data-rate is enough, why to bother in adding higher data-rate options?
    What are for Uncompressed options?
    There is trade data-rate/quality; is to you to chose what is more convenient for your workflow, but be aware of the pros and cons.
    Best,
    Rafael
    http://www.nagavideo.com
