Activity › Forums › Adobe After Effects › use 3d max or C4D with AE
Posted by Siell2001 on November 29, 2007 at 4:15 pmSteve Roberts replied 18 years, 10 months ago 2 Members · 5 Replies -
Steve Roberts
November 29, 2007 at 5:01 pmTo make movies small enough to load well within Flash, I recommend:
1) Swift3D, or
2) rendering to Flash format within Cinema 4D, or
3) using AE to render a SWF. Read the AE Help on “SWF” before doing that.Any of those three will *not* be interactive. They will only be movies. To get interaction, you will have to import them into a Flash project, and do the programming there. For more information, check out a Flash forum.
Siell2001
November 29, 2007 at 5:47 pmok thank but the i need is use elements or animation from 3d max o Cimena 4D with AE
Steve Roberts
November 29, 2007 at 6:06 pmYou must use Flash, Director, HTML, a programming language (Visual Basic?) or something else to create interaction. AE, Cinema 4D or MAX will not do it.
