Activity Forums Panasonic Cameras USB Power
  • USB Power
    Posted by Accountneedsrealnameupdate on August 17, 2006 at 7:54 am
    Does anyone know if the USB port on the camera is powered? More to the point, is it possible to use a portable hard drive like the LaCie Brick directly on the camera. The camera can act as a firewire host and transfer the contents of the P2 cards to an external hard drive, and the Brick can be used as a firewire drive while being powered from a USB connector via the supplied cable. The question is whether or not the USB connector on the camera could power the drive. Anyone ever tried this?
    https://www.lacie.com/products/product.htm?pid=10701
    Accountneedsrealnameupdate replied 20 years ago 1 Member · 1 Reply
