Activity Forums VEGAS Pro USB external drives
  • USB external drives
    Posted by Peter Heap on February 22, 2014 at 2:59 am
    Hi
    Firstly, I’ve had a look through past posts and haven’t been able to find an answer to my question.
    I’m using Vegas Pro 12 on a Samsung laptop with a i5 2.53GHz processor. I have 8gigs of RAM. I’m running Windows 7 64 bit.
    My laptop only has USB2 connectors and I think this is where my problem lies…I can’t get HD video to playback smoothly except at low resolution.
    And I’ve just noticed that when I try to play back at Best (Quarter) it automatically changes to Preview (Quarter).
    I feel I need to upgrade to a new computer with USB3 ports. Will this help? I’d prefer to keep this computer if I could as it’s only a couple of years old and I don’t do nearly as much editing as I used to when I first started using Vegas 4.
    I’ve seen a couple of posts that recommend using SATA drives in enclosures but I think my bottleneck is occurring with the USB2 cable.
    Looking forward to your thoughts
    Peter Heap
    Peter Heap
    Sydney
    Peter Heap replied 12 years, 6 months ago 5 Members · 5 Replies
  • Colin Morris
    February 22, 2014 at 4:46 am
    Hi Peter,
    I doubt it’s the USB unless you are running other usb drives and peripherals at the same time. Most likely your video card/memory/cpu combination. It may be better if you upgrade your internal drive to a larger, faster drive like SSD or a higher spec non-SSD. I upgraded my older laptop with a larger and faster Seagate Momentus drive. I then partitioned C, D, and E on the internal, with D holding the footage. I then render to an external drive or USB stick.
    Colin Mendez Morris
    ArsMusica
    http://www.arsmusica.ca
  • Stephen Crye
    February 22, 2014 at 4:59 am
    [Peter Heap] “I feel I need to upgrade to a new computer”
    That new computer smell is always great.
    On the subject of USB 3.0, my new work computer has that, and I am blown away at how fast my Samsung Extreme 64 GB thumb drive is on those USB 3.0 ports – I am hitting sustained 200 MByte/sec on reads, and in short bursts it can hit 400 MB/sec.
    https://www.storagereview.com/sandisk_extreme_usb_30_flash_drive_review
    Steve
    Win7 Pro X64 on Dell T7500, MultiTB SATA, 12GB RAM, nVidia Quadro 2000, Vegas 12, 11, 10, 9 DVDA 6.0 & 5.2(build 135) Sony HDR-CX550V, Panasonic GH3 with LUMIX G X VARIO 12-35mm / F2.8 ASPH, LUMIX G X VARIO 35-100mm / F2.8
  • Stephen Mann
    February 22, 2014 at 3:01 pm
    If you want to edit HD in an underpowered PC, then look at using Proxy editing. Search Help for “Proxy”, then read “Creating Proxy Files”.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Steve Rhoden
    February 22, 2014 at 3:13 pm
    “Most likely your video card/memory/cpu combination“.
    Also as Colin mentioned.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Peter Heap
    February 23, 2014 at 9:24 am
    Thanks for the replies everyone. Looks like I’ll be getting that new computer smell sooner than I expected:)
    cheers
    Peter Heap
    Sydney
