Activity Forums Apple Final Cut Pro Legacy USB external drive connection
  • USB external drive connection
    Posted by Melissa on April 25, 2005 at 7:07 pm
    I captured from FCP onto an external drive that is connected via a USB. The media is there so I’m assuming it worked. Is there any diference (from a firewire connection) in terms of the media or anything else that I should know about? Thank you for all you help.
    Melissa
    Troy E. parker replied 21 years, 4 months ago 2 Members · 1 Reply
  • Troy E. parker
    April 25, 2005 at 7:12 pm
    Hey…see the reply below to your thread for more info. In the long run I believe the Firewire the best bet, and is the standard for DV. Capture / Transfer ok, may create issues in playback / realtime effects etc….
    T
