Activity › Forums › Apple Final Cut Pro Legacy › USB Audio Capture
USB Audio Capture
Posted by Martin Nelson on May 13, 2011 at 6:40 pmI’ve happily been capturing scratch narration with a USB microphone using the log and capture tool. Until today. For some reason I can’t get the app to see —rather, hear— the microphone. Apple system settings recognize the mic is hooked up and working, but I can no longer get Log and Capture to recognize it.
Have I screwed up a setting somewhere?
Martin
2 x 2.26 Ghz Quad-Core Intel Xeon
12 GB RAM
OS 10.5.8
ATI Radeon HD 4870
FCP 7.0.2
Quicktime 7.6.6
Avid Media Composer 4.0.2.20Tosha O’neal replied 11 years, 9 months ago 4 Members · 5 Replies -
Cody Walters
May 14, 2011 at 2:58 amYou mean the Voice Over Tool not Log and Transfer right? Check your input setting on the voice over tool. Sometimes I have to click through and refresh so it receives the audio. You can also try refreshing your A/V device.
Cody Walters
JW Studio LLC
Houston Video Production
Houston Wedding VideosFinal Cut Studio 3
Adobe CS5 Master Suite
Panasonic HVX-200
Canon 7D -
Martin Nelson
May 16, 2011 at 2:10 pm[Cody Walters] “You mean the Voice Over Tool not Log and Transfer right?”
No, actually I prefer —and until the last few days have been able to use— the Log and Transfer tool. I find if I’m tracking narration for scenes that have not yet been cut, the VO tool workarounds are awkward. I would much more happily record audio clips into a bin and then cut them into a sequence as needed. I just can’t figure out what has gone awry.
Martin
12 GB RAM
OS 10.5.8
ATI Radeon HD 4870
FCP 7.0.2
Quicktime 7.6.6
Avid Media Composer 4.0.2.20 -
Andy Mees
May 16, 2011 at 3:41 pmDouble check your Audio Only capture preset :
Go to your FCP Audio/Video Settings… window (Cmd – Opt – Q) and switch to the Capture Presets tab
Select any capture preset and press the Duplicate button.
In the subsequent Capture Preset Editor window:
Set the Name and Description to USB Audio Only
Set the Quicktime Video Settings >> Digitizer to None
Set the Quicktime Audio Settings >> Device to USB Microphone, Format to 48 kHz
and then press OKNow open your Log and Capture window and switch to the Capture Settings tab
From the Device Control popup select Non-Controllable Device
and from the Capture/Inputl popup select USB Audio Only
Now switch to the Clip Settings tab and uncheck the Video checkbox (leave Audio checked).If everything is working you should see the levels jumping in the Clip Settings audio meter when you speak into the USB Mic.
If so, click Capture : Now and away you go. In future you should just be able to easily access the USB Audio Only capture preset as and when needed.Does that work? Hope so … its what works for me.
Best
Andy -
Martin Nelson
May 16, 2011 at 4:57 pmThanks Andy, that works perfectly. I have no idea what I’ve been doing in the past to get this to work, but this will carry me forward beautifully.
Martin
12 GB RAM
OS 10.5.8
ATI Radeon HD 4870
FCP 7.0.2
Quicktime 7.6.6
Tosha O’neal
December 4, 2014 at 9:46 pmAndy, you are my new best friend. I have changed jobs and have a different editing configuration and was sitting here banging my head against the desk saying…”It use to work…” Now it works again.
Thanks Bunches
Tosha
