Activity Forums Media 100 Usb 3.0
  • Usb 3.0
    Posted by Jack Shepard on July 2, 2014 at 8:50 pm
    I am working on a giant project that requires about 20tb worth of drive space. Everything is ProRes HQ 1920×1080. A tiny fraction of the footage is 4k. The budget just isn’t there for a bunch of thunderbolt drives.
    What is your experience with using Media 100 to edit from USB 3.0 drives? I’ve always used either firewire or thunderbolt.
    Thanks.
    Floh Peters replied 12 years, 2 months ago 4 Members · 4 Replies
  • Marcus Warren
    July 3, 2014 at 2:33 am
    I have no USB 3.0 capability but i am curious if eSata is an option for you?
  • Jack Shepard
    July 4, 2014 at 7:06 pm
    Yeah, that is possibly an option as well.
  • Robert Stone
    July 6, 2014 at 5:42 am
    I use OWC external drives with a USB 3 card in my MacPro 2008. Works great! Make sure you get a current PCIe card i.e. INATEK. I previously had a Sonnet Card that only worked part time. No problems now.
    Robert C. Stone
    https://HippieFilm.com
    https://MauiTVSpots.com
  • Floh Peters
    July 7, 2014 at 9:28 am
    Yes, using the Inatek cards as well. Works fine, at least for HD data rates. If you want to edit 4k files, you should look at your data rate for the codec you want to use to see if this is possible with USB3. Maybe you need some striped drives or a RAID to achieve the necessary data rates.
