Activity › Forums › Apple Final Cut Pro Legacy › USB 3.0 coming…4GB
USB 3.0 coming…4GB
Posted by Chris Borjis on September 19, 2007 at 6:22 pmwow, I would almost bet this will kill fibre channel.
Walter Biscardi replied 19 years ago 2 Members · 4 Replies -
Walter Biscardi
September 19, 2007 at 6:46 pm[Borjis] “wow, I would almost bet this will kill fibre channel.”
Only if it’s a sustained data rate. In theory USB 2.0 is fine for even DVCPro HD editing, but it doesn’t work because it can’t maintain a sustained data rate like Firewire, SATA and Fibre.
Right now we get almost 500MB/s on our eSATA systems with sustained data rates of no less than 400MB/s.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Walter Biscardi
September 19, 2007 at 7:06 pm[Borjis] “wow, I would almost bet this will kill fibre channel.”
By the way, just noticed your thread title is wrong.
It’s gb as in Gigabits. Not GB as in GigaBytes. The USB 3.0 is going to move in a much smaller data rate transfer than 4GB.
From the article you link to:
The current USB 2.0 version has a top data-transfer rate of 480 megabits per second, so a tenfold increase would be 4.8 gigabits per second.Gigabits. That’s not going to replace Fibre Channel anytime soon.
Chris Borjis
September 19, 2007 at 9:27 pmoops, the byte/bit thing has made a fool of me.
thanks for the correction Walter.
Walter Biscardi
September 20, 2007 at 12:27 am[Borjis] ”
oops, the byte/bit thing has made a fool of me.”
it gets everybody, no biggie.
