Activity › Forums › DaVinci Resolve › USB 3.0 and PCs
  • USB 3.0 and PCs
    Posted by William Edwards on May 20, 2012 at 4:00 pm
    Hello,
    A few things that I was researching. The majority of my projects are Apple Pro Res HQ files, and often times I am going on location. I am looking into the possibility of purchasing a PC instead of an iMac. I was wondering if anyone had luck with a PC using the Ultrastudio SDI USB 3.0 to go out to an SDI monitor? I am looking at an Alienware PC laptop with the Nvidia card.
    Also, if I had a desktop PC, is there another card one could purchase for an SDI monitor that is not a Decklink Extreme 3D? It’s a bit hefty on the price. There are the Kona cards, but that seems even more expensive.
    Thanks for your time!
    Chad Cooper replied 14 years, 3 months ago 3 Members · 2 Replies
  • Timo Teravainen
    May 21, 2012 at 7:13 pm
    I’m running Ultrastudio SDI USB 3-card on a PC with Asus P8P67 motherboard, it works just fine with Resolve. For most scenarios, it’s just as good as Decklink 3D Extreme card that I have on my other PC. Just be sure it’s compatible with your PC.
    As for other cards, I remember having read that Intensity Pro doesn’t work so well on a PC with Resolve..
  • Chad Cooper
    June 11, 2012 at 7:20 pm
    Intensity pro worked great for me in Resolve. As for the ultrastudio not working–if you have Nec/Renesas controllers you probably have to update them as per Blackmagic specs and download the nvidia driver.
