Activity Forums Panasonic Cameras Urgent! Timecode Synch problems with two cameras
  • Urgent! Timecode Synch problems with two cameras
    Posted by Ashley James on December 8, 2005 at 10:55 pm
    I am going to Vietnam to shoot a documentary and bringing my current “A” as well as my new “B.” I want to set the cameras up so that both cameras have the same timecode. I’ve gone through the instructions on Page 2 of the B manual, approached it very methodically and followed the instructions. Even had my engineer (I’m station manager of a government tv station) go through it with no success. We can get the player on the B (in this case the slave camera) to display the A’s (Master camera) timecode (using the 1394 firewire connection in the player mode, but when we put the B into camera mode the B looses connection with the A’s timecode and doesn’t sync anymore.
    Anyone have any suggestions and possibly e-mail me a work flow that would allow me to sync these cameras together. I called Panasonic Tech Support, got a busy signal with no way to talk to a technician.
    Thanks ahead of time for your help.
    Ashley James
    Station Manager,
    KTOP/Cable Channel 10
    City of Oakland, CA 94612
    510 238-3960
    (c) 510 593-8156
    Barry Green replied 20 years, 8 months ago 3 Members · 2 Replies
  • Tim Scarpino
    December 9, 2005 at 3:44 pm
    I assume the remote control does NOT control both the A and B cameras at the same time?
    If it does, you’re in luck, as your can simply use the remote control and the menu function to set the time code in the “free” mode. This is typically how it is done, at least w/two cameras from the same generation.
    Can’t help w/the firewire issue.
    Good luck,
    Tim
  • Barry Green
    December 12, 2005 at 9:54 am
    It only works in free-run mode, in TC Preset. Set both cameras to Free Run and TC Preset, and set the “B” to “DV TC IN”. Then link ’em and press the button.
    You cannot use the feature in Rec Run mode, or Regen.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available at https://www.dvxuser.com/articles/dvxbook/ and at Amazon (https://www.fiftv.com/db)
