Activity › Forums › Adobe Premiere Pro › *URGENT- PP CC 2014 to AE CC 2014 footage doesn’t match in AE
  • *URGENT- PP CC 2014 to AE CC 2014 footage doesn’t match in AE
    Posted by Brian Palmer on January 13, 2015 at 4:12 am
    **URGENT –Trying to move my (stacked) Premier Pro sequence footage to After Effects CC 2014 in order to do tracking and comping —but when importing a Premiere Pro CC 2014 sequence into After Effects CC 2014 through dynamic link the PP footage in the 1st video timeline (as seen in Premiere) is not lining up with the footage on the sequence above it when in the After Effects comp. The footage is there it’s just all over the place and I need the exact mirror of my PP seq in AE. Trying to meet a tight deadline so any suggestions are very much appreciated
    Brian Palmer replied 11 years, 8 months ago 3 Members · 4 Replies
  • Alex Udell
    January 13, 2015 at 3:47 pm
    Can you select the elements in PPro sequence, copy
    and then paste into and empty comp (correct resolution) in AE?
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Tim Kolb
    January 13, 2015 at 6:30 pm
    Is the issue that the clips are coming into AE untrimmed?
    Can you describe the kind of displacement…(“all over the place” is probably how you feel after editing the material, but there is probably some sort of trackable behavior if you look for it…)
    Do you have an in and out point n the Premiere Pro sequence?
    TimK,
    Director, Consultant
    Video Producer at I-CAR
  • Brian Palmer
    January 13, 2015 at 11:02 pm
    The clips may not be trimmed – that sounds like a logical
    issue. I will check.
    The issue is that the footage has different in and out points in AE but come in the correct sequence order causing us to have to readjust every in and out point by hand to match The PP edit sequence. I have a lot of media and this causes a massive workflow issue. Any suggestions on how to get the PP seq to come in to AE exactly the same as it is in PP would be greatly appreciated!! We are on a very tight deadline.
  • Brian Palmer
    January 13, 2015 at 11:03 pm
    And yes we do have our in and out points set in PP- Thx!
