Activity › Forums › Adobe Premiere Pro › Urgent! Please help! Image gets blurry after I rotate it.
Tclark replied 20 years, 4 months ago 5 Members · 13 Replies
Tclark
May 30, 2006 at 1:48 amOk, here is a strange thing. I did a frame export. One before and one after. Looking at just the frame itself in a bmp file there is hardly any difference. If I posted these you would probably would not see a difference on the web. So I figured I would output to dvd to see if it would be any different from what was on my external monitor. After I exported it it was still blurry. Even in the preview on export settings it shows it blurry. I am really confused.
No one else has this same problem?
Aanarav Sareen
May 31, 2006 at 6:29 amI got your email with the file attached. Now, I applied the rotation filter to it and it does blur, but very little. However, if that blur is not acceptable, apply the Sharpen filter and set the value between 3 and 5 and you should be OK. As a test, I just rotating a few of my clips and none of them blurred…
Aanarav Sareen
premiere@asvideoproductions.com -
Tclark
May 31, 2006 at 12:58 pmThanks for all your help Aanarav! Do you have any idea why ALL my clips blur? Do you think it might have something to do with lowering the sharpen adjustmaent on my cmaera? Although I would think that Premiere should keep the sharpness that is captured. Very strange that none of your clips blur. I tried the sharpen filters but they don’t match the clips that I do not have to rotate. You can still tell the difference. I am stumped on why I have the problem and you don’t.
Thanks again for your help.
