Activity Forums Panasonic Cameras URGENT PLEASE HELP: DV Start/Stop with 24PA DVX
  • URGENT PLEASE HELP: DV Start/Stop with 24PA DVX
    Posted by Gman2000 on September 3, 2005 at 9:24 pm
    Hey Guys,
    Im using the advanced pulldown preset and FCP is removing the advanced pulldown during capture. Using DV Start/Stop leaves me with markers that are shifted to the incorrect time (approximately 4/5ths off… which is about the ratio of 23.98 to 29.97) Is there anyway to shift the markers or anything, cause I have about 14 hours of footage that is going to be a pain in the ass to subclip.
    Gev
    Gman2000 replied 21 years ago 3 Members · 4 Replies
  • Gman2000
    September 5, 2005 at 4:29 pm
    WOW, I have posted this to many forums and have not got any answers, will someone at least please let me know, to make sure that it isn’t possible.
  • Noah Kadner
    September 5, 2005 at 4:53 pm
    Never heard of this issue- sorry. My suggestion would be to log and capture on a clip by clip basis rather than use the whole tape/auto detect method. Takes a little longer but much much more accuracy in TC.
    Noah
  • David Battistella
    September 5, 2005 at 9:00 pm
    There is a way to manualy move marker positions in FCP.
    Moving a Marker
    You can move a marker within a clip by repositioning the playhead or by entering a
    different starting timecode value. Using the playhead, you can only move a marker
    forward, not backward. If you want to move a marker backward or move a marker in a
    sequence, you must enter a new starting timecode value in the Edit Marker dialog.
    1 In the Viewer or Timeline, move the playhead to the location where you want to move
    the marker.
    2 Do one of the following:
  • Gman2000
    September 5, 2005 at 10:17 pm
    Thank You,
    I am going to try it!
