Activity Forums Apple Final Cut Pro Legacy URGENT need help
  • URGENT need help
    Posted by David Neidert on June 3, 2008 at 8:19 pm
    I am trying to output a last min 4:3 version of a 16:9 project. I am using compressor. I am sending a H.264 quicktime file. I put a letter box on it and output with a 720 x 480 setting but the footage is still squeezed a little it isn’t terrible but it isn’t good either. What do I do to get the letter box to look good while still having a 4:3 frame? I can’t seem to get any settings right and this has to be done immediately. Thanks in advance for any help you can provide.
    David
    Kevin Monahan replied 18 years, 3 months ago 5 Members · 13 Replies
  • 13 Replies
  • David Roth weiss
    June 3, 2008 at 8:22 pm
    [David Neidert] “I put a letter box on it and output with a 720 x 480 setting but the footage is still squeezed a little”
    How exactly did you do that? To help you we must know what did if you want us to correct it…
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • David Neidert
    June 3, 2008 at 8:25 pm
    I brought the footage into compressor straight from FCP. I choose the quicktime present, added a letter box filter and then in the geometry tab changed the dimensions of the frame to 720 x 480. Sorry I wasn’t clearer to begin with.
    David
  • David Neidert
    June 3, 2008 at 8:30 pm
    Also… Its squeezed horizontally not vertically. It seems like it is not completely scaling it into the letter box.
    David
  • Jeremy Garchow
    June 3, 2008 at 8:45 pm
    If it’s a 16×9 Sd project, you simply being in the movie, and in the gemotery tab add padding (they have presets for 16×9) or simply change the output frame size to something 16×9 such as 640×360.
  • David Roth weiss
    June 3, 2008 at 8:56 pm
    I do this all the time and I’m suddenly encountering a slight vertcal squeeze.
    I definitely don’t think you need the filter BTW in addition to changing th easpect ratio in the geometry tab.
    I’m still trying to see what’s cooking…
    David Roth Weiss
    Director/Editor
    Los Angeles
  • David Neidert
    June 3, 2008 at 9:00 pm
    I dropped the filter and I added a custom padding of about 50 on the top and bottom. It eliminates most of the issue I think. Post if you can figure out the problem. It is a subtle difference but still somewhat noticeable. It isn’t terrible on b-roll WS but interviews you can definitely tell.
    Let me know
    David
  • David Roth weiss
    June 3, 2008 at 9:19 pm
    In the encoder tab:
    Crop to: Custom (with zeros in all four places)
    Frame size: 720×480
    Pixel Aspect: Default for size
    Padding: 16×9 1/78:1 (should be 60 top and 60 bottom)
    David Roth Weiss
    Director/Editor
    Los Angeles
  • David Roth weiss
    June 3, 2008 at 10:04 pm
    Yuck!!! Sorry to step on your toes big fella…
    I had my head so buried in that problem I didn’t see your post. Its was really confounding me, because it seems my SOP with Compressor was suddenly not working as expected.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Jeremy Garchow
    June 3, 2008 at 10:22 pm
    Oh dude. No worries at all. I was beginning to think that no one could hear me.
    It’s okay, I’m used to it.
    Jeremy
  • Kevin Monahan
    June 4, 2008 at 4:53 pm
    Geometry Tab? Where’s that? You mean the MOTION tab right? 😉
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
