Activity Forums Adobe After Effects Urgent Invigorator help!!! Please!!
  • Andrew Yoole
    August 10, 2005 at 2:13 am
    The problem lies in the eps files – they are not made with Invigorator in mind. Invigorator artwork needs to be discreetly seperated as objects so that each object can be extruded, bevelled and have materials applied.
    The BMW logo, for example, has several problems. The letter B is made up of 3 paths, but the two “holes” in the B are not actually holes in the outer path, they are black objects placed on top of the B. Invigorator can’t extrude a B from three seperate Illustrator objects, so you need to make one compound path that has holes cut out of the main outer path with the two inner paths.
    Your best bet is to seperate elements in Illustrator that you need to move or add materials to individually, create compound paths where necessary, place them on independent layers and then import to Invigorator.
    If you post an email address I’ll send you the BMW logo corrected so you get my drift.
  • Henry
    August 10, 2005 at 3:00 am
    Thank you very much. hg_vb@hotmail.com
    Thanks for your help!
    Any chance you could look at the audi one too? It would be much appreciated.
    Thank you!!!
