Activity Forums Adobe Illustrator Urgent! Help required on Color replacement
  • Urgent! Help required on Color replacement
    Posted by Mills_mg on July 18, 2005 at 6:26 am
    Hi friends,
    I have a logo and I want to reduce the no. of colors in it. How I can achieve this?
    We want to replace the least used colors with matching other colors in the logo.
    I tired it with Image Size effect but it reduces the resolution we need to reduce the colors without affecting the resolution.
    Thnx.
    Jeff Kelley replied 21 years, 1 month ago 2 Members · 3 Replies
  • Mills_mg
    July 18, 2005 at 9:19 am
    How i can save my Logo as 8 bit or 256 colors BMP from Photoshop??
  • Mills_mg
    July 18, 2005 at 9:22 am
  • Jeff Kelley
    July 18, 2005 at 4:15 pm
    You can go up to the Image pulldown menu/mode/Index color. There you can pick the amount of colors but I can’t guarantee you’ll like the results.
    The best Idea is to redraw is in Illustrator, or even in photoshop. If it’s not to complex, you could use the magic wand to isolate each color.
    Best of luck
