Activity Forums Adobe After Effects Urgent Help Needed….Alpha channel issue
  • Urgent Help Needed….Alpha channel issue
    Posted by Chris Miller on January 15, 2008 at 11:07 pm
    First of all I need to apologise because I know this will probably be posted countless time but I have an important deadline tomorrow and am too stressed.
    I have created a animated graphic in After Effects which I want to import into Avid xpress and drop over the footage. Each time I render and import it places a black background behind the graphic.
    I need step by step instructions on how to set this graphic to export with a tranparent background into another program
    Please Help!
    Aharon Rabinowitz replied 18 years, 8 months ago 6 Members · 6 Replies
  • Victor Nash
    January 15, 2008 at 11:27 pm
    Did you render out your file as Millions of Colors+ (RGB+Alpha)?
  • Chris Miller
    January 15, 2008 at 11:36 pm
    Yer I did I tried it with ‘straight’ output mode
  • Alejandro Torres
    January 16, 2008 at 12:13 am
    Hi!
    What I usually do is export a jpg sequence with alpha channel activated, it will give you two sequences the original one and the alpha channel one, I don’t use Avid but I am almost sure it can manage jpg sequences as video as well as permitting you to use the alpha channel sequence to be used as a matte, I don’t use Avid but you could try this way.
    Regards
    Alejandro
  • Scott Cumbo
    January 16, 2008 at 5:42 am
    Make sure you have “invert alpha” selected on your import
    setting on the avid end of things.
    Scott Cumbo
    Editor
    Broadway Video, NYC
  • David Bogie
    January 16, 2008 at 8:29 pm
    Yes to most of the above but give yourself some slack. The section in the AE manual on alphas is long and confusing. I imagine the one in the Avid manual is, too. Read them carefully. Probably twice.
    bogiesan
  • Aharon Rabinowitz
    January 16, 2008 at 10:11 pm
