Activity Forums Adobe After Effects URGENT Help Needed!
  • URGENT Help Needed!
    Posted by Jay Shelton on August 2, 2008 at 1:04 am
    I was working on a project and had a power failure. Now my external FW800 will not mount. I pulled the two drives and plugged them directly into the SATA bay and Disk Warrior can see them both. It gave me the option to rebuild them. My question is since these two drives are RAID 0, will rebuilding them each individually ruin them or do further harm? I have tried to mount the external drive from two different machines, I have tried the FW800, FW400 and USB ports to no avail. I am really hoping someone can help me out on this. Thanks in advance!
    Jeremey @ DI
    Jay Shelton replied 18 years, 1 month ago 6 Members · 9 Replies
  • 9 Replies
  • Brendan Coots
    August 2, 2008 at 1:24 am
    If you do ANYTHING with the drives separately, you will lose all the data on them. RAID 0 is extremely risky, in that if anything goes funky you immediately lose all data. A power outage could definitely lead to this, and I hate to say it but you’re probably hosed.
    When using RAID 0 for anything, always do frequent backups to a different drive.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Jay Shelton
    August 2, 2008 at 2:33 am
    Ok, so after 4 hours of troubleshooting, pulling the drives out of the enclosure, etc. I think I have found the problem. It ended up being the external power supply. I just so happened to have another identical drive, and tried to plug in that cord instead, she fired right up. I guess I will be purchasing another power cord for the second unit.
    The most important lesson learned was that I really need to backup to either another drive or start using a mirrored raid set up. Looks like I will also be on the market for a backup drive. The few bucks you save just doesn’t add up to the real cost of the data lost!
    I just wanted to post the status, so the thread wouldn’t be left twisting.
    Jeremey @ DI
  • Daryl Booth
    August 2, 2008 at 8:24 am
    PHEW!!!
    salutations from codemonkey
  • Joe Moya
    August 2, 2008 at 7:19 pm
    Besides a good backup…
    … I have found a very good battery backup system plus a very good surge protector is as valuable as a good backup system… and… a reliable battery and surge protector can easily cost $300 and up.
    Power surges can wipe out internal or external backup drives if they are connected… in effect… the only good backup system is one that is not attached/connected and… stored in a fireproof vault, stored offsite or uploaded offsite… any combination of those storage locations will make for a truely good backup system… anything less will result in a fatal potential weak spot in the backup system.
    Joe
  • Daryl Booth
    August 3, 2008 at 7:02 am
    LOL, talk about living with the fear…
    I like to back up once a week and have the storage drive seperate from the sysyem unplugged. so thats good advice…
    But watch out for pixie data thieves…. they will attack when your alseep..
  • Christian Wheel
    August 4, 2008 at 7:13 pm
    If you want a decent alternative to Raid 0, try Raid 5. It uses the capacity of one drive to create redundency. So let’s say you have three 1TB hard drives and create a Raid 5 out of them. The capacity of the drive will be 2TB, but if any of the 3 drives fail, you’ll still be able to mount the drive and recover all your data.
    —– Christian Wheel —–
    Radio Host, 104.3 MyFM, Los Angeles
    Audio Production & Imaging
    MS Visual Studio Developer
    After Effects Enthusiast
  • Brendan Coots
    August 5, 2008 at 5:51 am
    RAID 5 is superior to RAID 0 when it comes to redundancy, but not when it comes to speed. In a setup with limited drive space (i.e. anything but an external enclosure) the speed of RAID 5 won’t be so hot.
    Everyone has their preference (and none are wrong) but I think smaller systems are better off with RAID 0 and routine backups.
    Brendan Coots
    Splitvision Digital
  • Scott Roberts
    August 6, 2008 at 6:14 am
    Is it a Lacie drive that you’re using? I have a Lacie external and I’ve gone through two power supplies already. I just ordered a new one and I’m waiting to receive it so I can get to some backup data.
    Color Grading presets for After Effects, Premiere, etc., plus free presets and more.
    LITTLE BLACK BIRD – PROFESSIONAL VISUAL EFFECTS
    https://www.littleblackbird.com
  • Jay Shelton
    August 7, 2008 at 2:55 pm
    No, actually it is not LaCie brand. That is good to know though that their power supplies are sometimes prone to failing.
    Right now my plan is to back up to bare drives and store them for further use, or to restore should a drive fail.
    I do appreciate all the feedback and ideas.
    Jeremey @ DI
