Activity › Forums › Avid Media Composer › Urgent help needed!
  • Urgent help needed!
    Posted by Carlos E. martinez on April 9, 2006 at 4:54 am
    I am trying to export a complete edit from Xpress and I am getting out-of sync problems.
    This is not the first time that I export anything from this edit, as I checked some parts to see how it looked and everything worked fine.
    As usual I expoprt using QT reference, witht the settings I have always used.
    Then I use Procoder to makethe conversion onto mpeg2.
    When I load the files I check the sync and everything is fine, but after wasted 6 hours on a conversion that turned out to be out of sync, I am now doing short runs to see what I get, and I am still getting out of sync audio.
    As you can imagine sync is fine on the program, and up to the Procoder, so I think two things might be happaening: Procoder is doing something wrong or the export is.
    Any suggestions to get me out of this mess I am in?
    Carlos E. martinez replied 20 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
