Activity › Forums › Adobe Premiere Pro › URGENT HELP!! export to AVI is blury!!!!
  • URGENT HELP!! export to AVI is blury!!!!
    Posted by Kelly Rooney on December 10, 2007 at 1:35 pm
    hi guys, im a uni student, im using PP2.0 and my source files are *.avi and *.mpeg have finished editing and when i chose to export the project as MOVIE the resulting AVI was very bad quality and blury!! i also tried Export>DVD ISO and got same result. am reasonably new at this. i have been teaching myself PP2.0 over the last couple of months. this is my first serious project im doing for a friend, and she needs it to play at her engagement in a few days!!
    could someone please help me?? what am i doing wrong? or not doing??
    have the education version of the Production Studio.
    ur help will be greatly appreciated.
    oh and the footage was taken on a sony fx1. two of my source files are SD and one(mpeg) is HD
    Lex Park replied 18 years, 9 months ago 5 Members · 10 Replies
  • 10 Replies
  • Vince Becquiot
    December 10, 2007 at 4:41 pm
    We will need to know your project settings and your export settings.
    Vince
  • Kelly Rooney
    December 11, 2007 at 12:52 am
    what setting would you need to know exactly so i can give you everything you need?
  • Vince Becquiot
    December 11, 2007 at 1:10 am
    Your project settings: DV NTSC? 480i?
    Your export settings: What codec are you using? What bitrate?
    Vince
  • Kelly Rooney
    December 11, 2007 at 12:10 pm
    DV PAL, my source is made up of 3 files, 2 is SD 780×540 and 1 is HD 1440×1080. Export as uncompressed AVI 16:9 PAL 25fps
  • Vince Becquiot
    December 11, 2007 at 4:00 pm
    So, by blurry, you don’t mean interlacing lines correct?
    The settings look fine to me, although you will get a loss of quality due to all the scaling going on.
    Could you post a frame export pic for us?
    Vince
  • Kelly Rooney
    December 12, 2007 at 12:47 am
    no its not interlacing, but ive lost that crisp definition and also all the shots ive done any work on(crop or colour correct) have come out fuzzy. kind of like what i see without my glasses on 🙂
    this may be abit of a silly thing to ask, but i dont know how to post a frame export pic.. could you please tell me how
  • Vince Becquiot
    December 12, 2007 at 1:32 am
    File > Export > Frame
    You will surely lose the detail on the high def clips.
    I’ll tell you when I see it.
    Vince
  • Perry Cheng
    December 12, 2007 at 1:11 pm
    Vince is correct that you will probably loose some quality with HD. Export as H.264 (only in CS3) will maintain a better quality. However, I guess what you need to know is what would you final audience be, TV, HDTV, or computer? It may not be as bad as you thought.
    Perry
  • Eric Gasteiger
    December 12, 2007 at 8:42 pm
    I believe that you are experiencing a lower field/upper field export issue. HDV is upper field first, SD is lower field first. Check your settings – you mixed field orders in your edit using SD and HD footage. When you export your “master” program in SD (lower field first) but you select to export HDV (upper field first) you will get a blurred result. Or visa-versa.
  • Lex Park
    December 14, 2007 at 4:28 pm
    I agree with Perry. If the final playback will be on a TV, it may look fine on it, yet look messed up on a standard computer monitor. Give it a test run to see…
    – The Foonshoe
